QuickTURN2D v1.23 released 7th October 2015
//v1.23 - 7th October 2015 - The created GCode moves internal drill operations straight down to the x=0 position in line with the center of the billet, rather than to the edge of the billet first and then down.
The spindle is always brought to a halt in the GCode when a tool is changed.
There is an option under machine parameters to use coolant. When checked, the coolant on MCode (Mcode 8) is used at the start of the code, and is only stopped before a toolchange or at the end of the program.
Check here to download the latest version of all software:
https://www.denfordata.com/downloads/Qui ... _v1.23.zip
