8 station ATC vs 6 station ATC - differences?
in order to get an 8 station atc in a triac did denford position the tool changer differently on the 8 version so it fits?
Re: 8 station ATC vs 6 station ATC - differences?
andy_con wrote:in order to get an 8 station atc in a triac did denford position the tool changer differently on the 8 version so it fits?
I think it was just the tool holder sizes that determined the number of pots, 8 station were BT30 and the 6 station were BT35 :D
The machines we make now use the same tools but the holders on the 8 station are slightly smaller & the disc is slightly bigger.
the current atc tool holder looks to be around 200mm
well according to my drawing I can get 8 tools in
anyone got any tips on how to remove the ally disc that holds all the tools, cant seem to work it out??
subject to the 3 underneath, I cant find any screws or grubs anywhere. so im assuming its force that removed the tool holder?
ok with a few tips from tom I have the ATC off.
I have two questions for denford
do you know exact distance between hole centres? are there any drawings anywhere?
and same do you know have any drawings showing position of these holes in relation to centre hole?
ill just continue posting, even if there is a lack of help being offered ;)
ended up taking the atc arm out that holds the tools so I could CAD it up properly.
new 8 station design with nema 23 driving it
Hope these drawings help.
Have work to do as well as creating pdf's so sorry about the delay.
TR17_0700_1.pdf
(272.17 KiB) Downloaded 920 times
TR17_0700_2.pdf
(156.94 KiB) Downloaded 1003 times
TR3_0767.pdf
(429.68 KiB) Downloaded 897 times
TR3_0765.pdf
(271.49 KiB) Downloaded 879 times
Steve wrote:Hope these drawings help.
they are perfect many many thanks.
out of interest did denford make two different TR3_0767 as the centre of the two bearings on mine measures 47mm?
I am not sure. This is the 8 station version I think. Maybe a different part number on the 6 station one.
Steve wrote:I am not sure. This is the 8 station version I think. Maybe a different part number on the 6 station one.
fair enough thanks.
did I see in the nova section denford sell a powered drawbar setup?
im going all out now!
by flipped the part that holds the bt35 tool in you can bunch them closer together and get 10 tools on a 210mm disk
Hi Denford fit a powered drawbar to the current VMC 1300.
It works much the same as the NovaMill and Triac.
I cant supply drawings for current machines but some of the parts are common and could be supplied.
It uses 44 springs in the chain and a similar power transmission to the NovaMill.
Steve wrote:Hi Denford fit a powered drawbar to the current VMC 1300.
ok many thanks
making mountings and things is the easy part its getting hold of a decent powered drawbar setup that's the hard bit.
may enquire about pricing at some point
