Retrofitting Spindle Digital RPM meter to a Viceroy lathe
Hello
I found a Chinese supplier of cheap digital tachometers specifically designed for machine tool applications.
The trigger 1 pulse per revolution and measure the period between pulses. This means good update times even at low rpm.
They are available in red and blue. I fitted a blue one to the Viceroy to match the colour scheme.
I was able to modify an existing bushing on the spindle to fit a trigger magnet. The bushing retains the rotating components on the spindle and is not loaded.
I was able to mount the sensor on a bracket within the headstock.
The existing bushing modified by potting a magnet in a milled slot.  A similar slot was milled on the other side to balance the bushing.
IMG_4641 (768 x 576).jpg (32.34 KiB) Viewed 22039 times
A heavy duty bracket to hold the sensor.
IMG_4621 (768 x 576).jpg (32.98 KiB) Viewed 22039 times
The sensor mounted inside the headstock.  It is bolted to holes drilled and threaded from outside the headstock.
IMG_4640 (600 x 450).jpg (78.82 KiB) Viewed 22039 times
A paper/cardboard  mock up of the control panel with RPM meter to test ergonomics.
IMG_4644 (600 x 450).jpg (32.61 KiB) Viewed 22039 times
Dazz
Re: Retrofitting Spindle Digital RPM meter to a Viceroy lath
Here is the finished control panel.
IMG_4722 (600 x 450).jpg (40.19 KiB) Viewed 20677 times
Dazz
