X axis drive failed
Hi all,
On my microrouter pro, the x axis drive has stopped working, I have checked the voltage going to the drive which is good, I have swapped over the connector and fitted it to the y axis and the x axis motor moves fine, which tells me that there is an issue with the drive, there are no leds ON, when power is put to the drive either.
Where can I get the drive repaired or are there any replacement drives available.
Any help and advice greatly appreciated.
Re: X axis drive failed
Is there a phone number at denford u can ring for repairs?
Mr Magoo, Martin, Steve
