Novamill Spindle
Hello all. I am hoping the admin or a kind member can help me out. I purchased a Novamill that was striped of its ATC spindle assembly. I am OK with having one made locally and have the RM6-100 diagram which gives a nice overview. Is there anyone who has dimensioned drawings or is kind enough to measure and photo a spindle assembly with the appropriate measurements to re-create this unit? I have sent requests into Denford via email for information, but I have not received a reply from them. I fear they either don't know, or are not willing to assist. Thanks!
Re: Novamill Spindle
Did you have any luck with this ?
Can anyone clarify for me if the disc springs shown in drawing RM6/100 have a spacer between the upper and lower stacks, or if there is actually a single stack with rather more than the 14 springs shown?
No spacers & 27 Disc Springs according to the parts list.
Thanks Martin.
Is the parts list available? The assembly drawings are of limited use without parts list?
What about part drawings - or is the ATC (or parts of it) used in a current/recent model ?
I will try to post them on Monday
Hope this helps
DOC120115.pdf
(484.46 KiB) Downloaded 2033 times
Thanks - that is very helpful.
Are similar parts lists available for drawings RM6_700 & RM6_700C ? (the ATC carousel).
I will have a look but not in the factory until the end of the week.
