Machine pauses at each point when machining
Hi Guys. My first post here but I have read a lot of the forum for this machine. I am having a problem with my MicroRouter Compact. Can you help?
I am running V2.23 with Windows XP Pro on a Dell PC. The firmware is up to date (5216, FPGA 17 & CPLD 9) using Next Step on an NS control card (the newest one with the green LED) and all would seem to be good in terms of comms and control.
However, when the machine runs the GCode, it pauses for a quarter of a second at each point. It is as if it is a child learning to read... "The. Cat. Sat. On. The. Mat..." etc. It can't seem to read ahead and go smoothly from point to point. This not only slows the machine down but enables the tool to burn the timber.
When jogging, it works fine. When machining a G03 interpolated curve, it moves fine but when running a .fnc file from Cut3D, it pauses at each point. As you can imagine, it's quite frustrating. I have spent ages adjusting baud rates and all sorts of parameters to no effect. (Well, no positive effect anyway.)
Can anyone point me toward a specific setting that might be responsible for this please?
Many thanks in advance.
Re: Machine pauses at each point when machining
Make sure you are running in TURBO mode?
The button should be in the control panel window when you are in auto mode.
In the latest software we default TURBO to be on.
Thanks for getting back to me so soon Martin. I have been itching to get back to the shop and try it. Can it really be that simple?! I feel slightly foolish. :D
I went to the machine today and another gremlin has surfaced. When i try to connect to it, it erases the flash and then a box appears saying "Invalid Image Format". I've not seen this before and can't tell you what, if anything, I have done to generate this fault. Any ideas?
Thanks again Mr. Guru.
It may be worth updating VRMilling to version 2.31 which you can download FOC from the Denford website. Make sure you have a copy of the licence key first though.
I had done something to make the firmware revert to an older version so ran Easy Upgrader 2 and it connected straight away. I then uploaded a file, pressed the turbo button as you suggested, and she flies along!!
All sorted now Martin. Thanks very much indeed sir! 8)
