My Siemens Micromaster 410 has broken.
They do not make it any more.
Can I use a Siemens Sinamics G110 inverter w/filter, 0.37kW
I use it on my orac lathe spindle motor.
Any help would be great.
Hardware/Software: Solidworks
HSMXpress
Denford Orac
XYZ Milling Machine
Cubex Duo 3D Printer
HSMXpress
Denford Orac
XYZ Milling Machine
HSMXpress
Denford Orac
XYZ Milling Machine
HSMXpress
Denford Orac
XYZ Milling Machine
Ok,
A new update.
I am going to use a Sinamics G110 Inverter with filter 0.37kw with Din Rail Mount (RS No: 505-2129)
This should match the original motor on the lathe.
Controlling it with a Cnc4pc C11T Breakout board.
Also the following power supplies:
Meanwell MDR-10-5 5Vdc 2A Din Rail Mount (RS No: 712-7402)
Meanwell MDR-10-12 12Vdc 0.84A Din Rail Mount (RS No: 712-7411)
Controlling it with Mach3
Hope this will help some one.
A new update.
