Z axis problem
I have a Triac with Next Move ST USB controller and the current VR Milling software. I am seeing what I think is a failure on the Z axis. Frequently the machine fails to home on the Z axis after connecting to the machine via VR Milling. The z axis position in the software increments continually (this is with the machine in the homed position for all axis). If I used the hidden home button instead I can move the X and Y axis but not the Z. Leaving the machine switched off for some time will temporarily cure the problem.
Does anyone recognise this issue? Am I seeing a failure in Z axis motor drive?
Also, are the driver boards identical on each axis? If so, presumably I can swap the board connections with another axis to try and narrow down the issue?
I have had the machine for a year now and have only just had the time to try some milling so this is quite furstrating....
Edward
Re: Z axis problem
Yes the drives are the same so you should be able to use the secret home button to narrow down the fault.
Re: Z axis problem
I was trying the machine again and a new symptom has appeared the spindle is descending of its own accord! No program running and no one near the keyboard. Does this point to a particular failure?
Re: Z axis problem
I swapped the cards and the problem moved to the other axis so I am replacing the driver card.
Mr Magoo, Martin, Steve
