Mitsubishi RV-M1 robot programming problem
Hi everyone.
I have some problems with programming rv-m1. I am using mitsubishi comm server. I have sent command with this program with using yellow command bar and it worked.
[img]
https://lh3.googleusercontent.com/-BduX ... Resim1.jpg
[/img]
I want to use the text field on this program. But when I use it, it isnot sending th commands to the robot. How can I use this program?
thanks.
Best regards
Makinahmet.
Re: Mitsubishi RV-M1 robot programming problem
well, I have solved the problem. Only must specify cartesian coordinates sensible. So robot can move the coordinate. Like in manual Fig 5.11.1.
