Hello to you all,
Can anyone one here help me as I need to make a replacement coolant tank for this lathe I have re-built which is missing a coolant tank and accessories. What is needed is some engineering drawings or dimensioned sketches of and an actual tank so I can make a replacement. Or someone sell me one from a decommissioned Denford TDS lathe.
Any advice or help would be appreciated.
Kindest regards, John R.
John,
if you look through the parts lists here:
https://www.denfordata.com/downloads/for ... imised.pdf
and here
viewtopic.php?f=50&t=2961
to find out the relevant drawing numbers, it will make locating the drawings a bit easier.
and here
Dear Andy,
Thank you for the links and I have now found the drawing numbers for the parts for the compound idler gears and the coolant parts from the link to the topic post.
Are the following drawing available:?
ML100/152
" /998
" /997
" /132
" /208A
" /214A
" /219
If so where can the drawings be downloaded or acquired?
ML100/152
" /998
" /997
" /132
" /208A
" /214A
" /219
