Quatromill
Does anyone out there have a parameter listing for Quatromill with Heidenhain TNC 355 control, sorry just found out its a 355 not a 150
Re: Quatromill
PARAMETER LIST FOR QUATRO WITH TNC355 31/03/89
QUATRO-E.zip
(1.13 KiB) Downloaded 1131 times
Re: Quatromill
Thanks for parameters, unfortunately they are for machine with power drawbar we cannot get rid off low air pressure message to allow machine to reference, need to know which PLC parameter is for low air, still have hope just need parameters from machine with stud drawbar. Regards Blakey
Re: Quatromill
Hi Blakey,
I am not in the office for a couple of weeks but parameter 158 does spring to mind. Whichever parameter it was set in binary so you could try setting it to 1 or 2 or 4 or 8 or 16 or 32. (I may be wrong with 158 though)
The alternative would be to link the air pressure in the electrical cabinet. If you have the drawing it should be easy to locate the wire that would need linking.
