DXF files
A longtime Denford customer writes:
Please give me the steps to transfer the 90 + DXF files from Denford Inc. Website (i.e. www.denford.com > Support > Downloads > DXF Files > All DXF Files). When I try downloading them they are not in the data file under the Denford folder. Please help! Thank you.
DXF files
I was told that you are trying to Download 90+ DXF files from the Denford Inc. Website
Here is how you do it!
https://www.denford.com/USAHOME.htm > Support > Downloads > DXF Files >
All DXF Files
File Download window will appear ready to download dxfall.exe
Download to whatever directory you want, just remember the location.
Next execute the file from this location (suggestion: download it to the C:\Denford folder)
This will prompt you to UNZIP the file and the location you which to unzip it too.
Type C:\Denford\data (or your desired location)
Click on the UNZIP
You should see 97 DXF file in this directory now!
Hope this helps!
By the way, these same DXF files are now included in the installation of the current (31st Aug 2006) version of QuickCAM 2D Design.
v1.3 is available here:
https://www.denfordata.com/downloads/qui ... gn_1_3.zip
(Be sure to check for further updates)
