QuickCAM 2D v1.3 released 31st Aug 2006
Get the latest version of QuickCAM 2D Design here:
https://www.denfordata.com/downloads/qui ... gn_1_3.zip
Updates include:
  • 1. Triac PNC post processer support (will create single quadrant arcs and circles now)
    2. Added vertex number to vertex editor box - so you can find the start and end of closed polylines
    3. help contents menu turned off as there isn't any yet (use the tutorials instead)
    4. Materials and tooling editing has been simplified, and will use VR Milling V5 tooling and materials, if it is installed
    5. Images can now be rotated in the image import window
    6. Metric or Inch units selector menu added
    7. If VR Milling V5 is installed, then CNC files posted, will be automatically opened in VR Milling - can be turned off by a new menu checkbox
    8. The picking of entities within the machining plans is easier and more accurate
    9. Altered the CAM wizard to allow buttons to be visible on a 800x600 screen resolution
