VR Turning v1.33 released 25th June 2013
Posted: Thu 18 Oct , 2012 9:39 am
						// v1.32 - 25/1/2013  - Fix to G81 cycle so that it is modal, eg G81 Z-10; Z-20; Z-30 will remain in G81 drilling mode until G0/1/2 or 3 is programmed
// v1.32 - 31/1/2013 - Fix to Print > offsets to show the X offset value as a diameter if not in RadiusProgramming mode
// v1.32 - 19/3/2013 - added Turn370, nb Now, if Tool Change Auto type is set to -1 then VRT and Mint uses the nvLong[19] location to determine turret type.
// v1.32 - 19/3/2013 - if mint files per machine don't exist, the file missing error can be removed by adding BigMint2.mnt to the .ini file: Mint File=C:\Program Files\Denford\VRTurning\BigMint2.mnt
// v1.32 - 21/3/2013 - fix so Toollist.current is updated when the control panel Tool number changes (eg. when homing and turret changes to tool 1 without a Tool call)
// to do with error where tool editor opened up with wrong tool showing.
// v1.32 - 21/3/2013 - changes in control panel - button is now spindle on/off
// v1.33 - 24/6/2013 - fix to TP135 toolchange to compensate for bouncing strobe switch
Check here to download the latest version of all software:
