Extractor LED Board
I have just taken the extractor board out of the Advantage unit as the LED's do not work showing the status of the filters. I have checked all the fuses and these are OK and cannot see anything wrong with the board visually. I have removed the pipe from the vacuum sensor but I cant remember which side it should fit too.
Anyone any ideas if I have put it on right?
Re: Extractor LED Board
The manufacturer has confirmed you have got it connected correctly
