VR Milling Ver 2 “class not registered error”
Q. On VR Milling ver 2.30 got a “class not registered” error
A. This means that a MINT OCX is not registering
FIX 1. Logged on as a different user on the network
2. Reinstall software logged on as an ADMINISTRATOR
On windows 98 try running WORKBENCH.EXE but don’t use it, you could get a message “NO CONTROLLER FOUND. FAULT WITH COM PORT 2”
Re start VR Milling and this should get rid of the “class not registered” error.
Note some one got the error message “ CHECK E STOP, CABLE CONNECTED “ error doing this so sent out a new NEXTSTEP top board
