Viceroy TDS29 Drill Sharpener
Post by Denford Admin » Fri 16 Mar , 2012 15:03 pm
Viceroy TDS29 Drill Sharpener scanned drawings
Viceroy-TDS29-Drill-Sharpener.pdf
(746.38 KiB) Downloaded 1589 times
Andy B
Re: Viceroy TDS29 Drill Sharpener
Post by Andy B » Tue 28 Jul , 2020 7:33 am
There is more TDS29 / DSM info in this linked thread.
It is confusingly headed 'Sharpedge'.
Andy B
Post by Andy B » Wed 29 Jul , 2020 8:05 am
The Drill Sharpening machine (DSM) was one of several designs that Denford acquired or badged - others including the 'Royal' shaper from Realm Engineering of Croydon, Surrey, and the 'Horizon' milling machine from AEW Engineering in Norfolk.
The design apparently came from Engineering Developments (Rhyl) Ltd, but I can find nothing about this company.
The DSM had a major redesign in 1978 when most threads were changed from Whitworth or BA sizes to metric, the motor was encased and had a different mounting mechanism, and the label was changed from a discrete 'Viceroy' badge on the motor to a much larger plate on the main bed casting.
Its design differed from most cutter grinders; instead of the tool being swung across the grinding wheel, the wheel head pivoted and drive was transmitted via a toothed belt.
Parts list:
DSM-Parts-List.pdf
(523.4 KiB) Downloaded 754 times
Redesign Mod Note:
Mod 2623-78.pdf
(303.04 KiB) Downloaded 817 times
