Compact 1000 Pro
I have a brand new Compact 1000 Pro running VR CNC Milling 5 (5-43). My first attempt to machine an F1 car resulted in an error message of "error code 1227". After rebooting everything I was able to get to the "homing" routine after which it timed out within 5 seconds. I tried a new USB cable, replacing the one that came with the machine and was able to machine one side of the F1 block. When I flipped the block and started to run the other side I received a "timeout on ICM (host TX)" message and the "error code 1227" message. I switched the USB to another port, made sure no power saver settings were on, no screen saver active, rebooted the machine and the computer. Same error messages.
Re: Compact 1000 Pro
Are you able to try the machine with another PC? Just so we can rule out one or the other.
