Denford Mirac Lathe '2000
Need Automatic Indexing 8 Station toolpost for my Denford Mirac Lathe (year 2000, serial nr.00081). I could use some help where to look.. Thanks.
Re: Denford Mirac Lathe '2000
From our records, the machine had a Denford-made DM8 toolpost with Omron drive:
OMRON
3G3JV 0.55KW
N9P1931-001-12
What has happened to the old one ? Does it need replacing or repairing ?
Some parts of it has worn, for example pic - parts inner diameter is now 1,5mm larger; rotary switch (ordered one already) and hooks or jaws (i don't know how to call them :) ). I think it rather needs to be replaced.
Unfortunately we do not have this part
This specific part or entire toolpost?
Our designer is off work at the moment, so we will have to wait for his return to see what or if we can offer
Hi! Did he come back?
He's not back yet.
We do not have any parts for the DM 8 turret.
Attached is a link to the turret drawing.
https://www.denfordata.com/projectimages ... rawing.pdf
Can you identify the part you require and we can then have a look to see if there is anything we can do to help?
This post may be helpfull also
viewtopic.php?f=40&t=157
So, the parts:
TP126/3 - Worm gear
TP126/5 - Reversing Bush
TP126/8 - Locking Pawl
Last week I received and installed new Rotary Switch (Grayhill), now the machine functions a bit better. But I wish to replace all worn parts if possible.
kind regards,
Karlis :)
One more:
TP126/9 - Locating Pawl
Sorry to say we dont stock any of the items but the Worm gear was made by Hewwitt & Topham
Royd Way, Keighley, West Yorkshire BD21 3LG United Kingdom Telephone: +44 (0) 1535 602587
I have attached drawings for all the parts. I am sure you can make your own on some of them but can subcontract the others.
Tp126_09_V3.pdf
(271.3 KiB) Downloaded 1049 times
Tp126_08_V3.pdf
(271.12 KiB) Downloaded 1032 times
TP126_05_V3.pdf
(387.55 KiB) Downloaded 1012 times
Tp126_03.pdf
(102.91 KiB) Downloaded 1074 times
