hi, Is it possible to draw the part inside the billet i.e. start the line at z:-15mm? it seems to allways start from z: 0
I have a 2 op job that i want to turn around in the chuck and i want to face off the material that was in the chuck and then do some boring.
cheers
starting a line inside the billet
Re: starting a line inside the billet
Starting from Z0 is fixed into the software to keep things from getting too complicated.
If you're saying that the jobo is 15mm shorter when turned around, why not use 2 work offsets where the Z differs by 15mm ?
Many thanks for your quick response, Ill try your idea
