Folks,
I also am having problems with the Porter Cable router's spindle working. I changed the brushes and also the spindle 6.3 Amp fuse. When I run the machine, the router initially turns on, but immediately blows the fuse again. I shop vac the entire machine, blew air in the bushes holes and throughout the router. I cleaned out the E-stop also. Should I insert a 10 amp slow blow fuse instead of a 6.3 amp? Thanks.
