easychange collet wanted
anyone got a 3mm collet for an easychange milling chuck that they'd like to sell? (only need the collet)
Would be interested in other sizes, and in a drill chuck adaptor as well.
25 years as Electronics design Engineer, cnc machines used for manufacture of prototypes. Have Boxford 240tcl and 260vmc, Denford starmill, used to have an Orac. All converted to run Mach3. Happy to try to help with any tech issues.
Re: easychange collet wanted
Hi Andy - the collets can be had from Chronos for about £10 (Pozilocks) and the drill chuck adaptors from J&L tooling (about £60). I bit the bullet and got an ER32 chuck instead as I already have ER collets and plain shank tooling.
I have been trying to source easychange tooling too :D
i think that MSC J/L have them on special this month https://www.mscjlindustrial.co.uk/CGI/INPDFF?PMCTLG=12 try the bottom of page 14.
if you are after cheap ER collets i tend to use https://www.colletsdirect.co.uk/index.asp for 1 offs. for sets i use fleabay and get them from HK. they are manufactured in china. the last batch of 4 BT30 holders i purchased were ordered on thursday and arrived on monday morning, not bad delivery from china. the quality is good as well.
Thanks for the replies,
The posilock collets wouldn't fit the standard easychange collet holder- they look a lot more like the vertex set I have for my manual mill.
I'd seen the other easychange collet chuck (Coventry) but it appears to use a different collet style. Think it'll probably be easier to get one of these and use the readily available collets.
For reference, my collet chucks take 'Crawford Collets'.
Thanks again.
A full range of "Easy Change" toolholder including Weldon end mill holders, ER 16, 20, 25 and 32 collet chucks, face mill holders, Jacobs drill chuck arbors, Morse taper 1,2 and 3 etc, etc.
Go here https://rotagriponline.com/index.php?opt ... &Itemid=29
Browsing the links posted here I can now see that the collets I've got are DA20. This seems to be different to the currently available collet holders that take an ER20.
I'll probably go ahead and buy a new collet chuck to allow me to use the ER20s.
Thanks All.
ah yeah i have the DA collets andy i use the holders in my machine and have a few spares collets
Just to check they are the right DA collets the Dia is 11.5mm and the shoulder is 13.5 in dia sound right??
PETER WILES
Thanks for everyones input. I've been able to determine they are DA collets, and managed to buy some from Ebay, listed as DA200 collets.
On another note, just finished converting my Starmill to run Mach3 so if anyone needs any pointers let me know. Simple job to do if you keep the drives and most of the original electronics.
