I wrote this windows program for a mate some years ago. Basically it converts .sta files to text format, and will read txt files (which are in the correct format) and convert them to .sta and optionally write the .sts.
He had no problems. I have only verified it on the Starturn Dos software running in dosbox. I don't have a Starturn to test it on! So I accept no responsibility for the results! Use at own risk! There is no support (my limited time). I have my own cnc mill with a Baldor servo card and wrote all the drive software for it if thats any qualification!
It does not check the syntax, does not check that the gcode is of the correct limited subset, does not check file length. But does allow text editing of sta files.
It's free unless you make a profit out of it! If anyone is interested they can have the source, but if you make any money, don't forget me
If somone would like to verify it that would be great. If there are bugs, they can be attended to ... in time. Not tested on win7. It's standalone, virus checked as much as is possible, just run the exe. The important additional file is generic.txt, this contains the default sts parameters.
Enjoy!
Tom
