Techsoft "Line should start with a Keyword"
Problem:
"Line should start with a Keyword" error when post processing
Solution 1:
The file C:\DENFORD\MACHDATA.INI has an incorrect entry
The line that reads...
MicroRouter (metric)=d:\denford\config\fanucm.ini
should read
MicroRouter (metric)=c:\denford\config\fanucm.ini
NOTE THE DRIVE LETTER !
Solution 2:
The file C:\DENFORD\CONFIG\FANUCM.INI contains invalid paths in the LIBRARY FILE= entries
Check each entry in this INI file, making sure the LIBRARY FILE= entries contain a complete absolute path, and not a relative path.
An example of an invalid relative path is...
LIBRARY FILE=..\FANUCM.SLB
An example of an valid absolute path is...
LIBRARY FILE=C:\DENFORD\LIBS\FANUCM.SLB
Solution 3:
Make sure the C:\DENFORD\CONFIG\FANUCM.INI file exists
Make sure the C:\DENFORD\LIBS\FANUCM.SLB file exists
All three of these causes and solutions have been seen out in the field
Solution 1:
should read
Solution 2:
Solution 3:
