Wanted oil flow restrictor for triac
Does anyone have an oil flow restrictor from the autolube system on a 1990 triac its marked M21 and fits in the oil dividing blocks?
Re: Wanted oil flow restrictor for triac
boomstrike wrote:Does anyone have an oil flow restrictor from the autolube system on a 1990 triac its marked M21 and fits in the oil dividing blocks?
Is it a flow restrictor or is it a metering unit?
You might not know this, but these are standard industrial parts not specific to the Triac.
Assuming the machine uses the same components in its lube system as an Easiturn, have a look at https://www.lubetec.co.uk/ or (with the caveat that the threads might not be metric) www.arceurotrade.co.uk
You are righ djc it is a metering unit. Thanks for the links https://www.arceurotrade.co.uk/ have the exact item I require I will order after christmas
