PCB Engraver control software v1.4 released 25th Oct 2010
// v1.4 changes to gerber reader incorporated so that gerber created by Osmond Quartz will read (it failed because of multiple moves per line, so now split lines according to * postion)
// v1.4 fix to Gerber import - to do with undefined %FS leading or trailing bit - default (ie not defined was/could be wrong)
// v1.4 had to add maxspeed to mint - to do with it working on v5414 firmware.
// v1.4 removed .NET requirement from app and CD. Updated Quickstart guide.
Check here for latest versions:
