TDS/C/R/CNC (Feb 1985) ORAC Lathe - Speed control problem
Customer Writes ..............
New to this site.
We have a problem with the speed contol on our lathe.
Model:TDS/C/R/CNC (Feb 1985)
When in manual mode, the spindle will start, however when we try to vary the speed, via the +ve / -ve keys on the spindle speed section of the keyboard, there is no response in either direction.
At present the spindle speed is varying (self-fluctuating) between 100RPM & 120RPM.
Does anybody have a solution?
Thank You
Re: TDS/C/R/CNC (Feb 1985) Lathe - Speed control problem
What is a TDS/C/R/CNC?
Is it an Easiturn / Micromaster?
Picture of the machine might help to at least find manuals / schematics.
Just a couple of quick questions.
Have you messed around in the front panel of the machine recently? There is a 2 core ribbon cable that plugs in to P2 on the TIO.C board. If it is removed & refitted upside down then you get the same symptoms as you are reporting)
Do the buttons beep when pressed?
We also have a section on the Denford Forum for the Orac which may be of help. viewforum.php?f=43&start=0
ORAC
resized_Picture 120 (Small).jpg (52.58 KiB) Viewed 5301 times
resized_Picture 119 (Small).jpg (51.13 KiB) Viewed 5301 times
resized_Picture 117 (Small).jpg (49.74 KiB) Viewed 5301 times
resized_Picture 116 (Small).jpg (49.35 KiB) Viewed 5301 times
Picture 111 (Small).jpg (41.77 KiB) Viewed 5301 times
Picture 122 (Small).jpg (67.3 KiB) Viewed 5301 times
