Homeless parameter?
Posted: Mon 27 Sep , 2010 18:03 pm
						Hi y'all,
Again, thank all of you for your help. I have most everything working now, but am not out of the woods yet.
I loaded the parameters you gave me last month, and it definitely helped.
I do have a question (again). When you home the machine, isn't it supposed to go to zero? The reason I ask is when I try to run a program that was already loaded, it asks to zero the machine. When I home the machine, it goes to X - 5.1940 and Z - 1.840. It then gives error messages when you try to start the program.
Is there a procedure to get the machine to home to zero that I may be missing? I tried the settings from the files you gave me, and most everything is working now. I think the range that controls the home position is N0700 to N0726. Also, I tried to change N8140 to N8151, but the controller will not let me do that. Is this a protected area?
Thanks,
Bill Gillen
Thanks,
Bill Gillen
