have an easymill 3 showing the 2nd red light down on the z axis digiplan driver , i have swapped the driver for the y axis and the fault still shows on the z axis , so must be on the machine somewhere , any pointers please anyone .
thanks all
Have you got the digiplan manual ?
eg:
eg:
Find out now if it's in the wiring or motor by swapping the motors9.6 Axis Card LED 1
Illumination of this LED indicates a short circuit across the two
motor terminals.
9.7 Axis Card LED 2
Illumination of this LED indicates that excessive continuous current
has been detected, and the drive has folded back. See Section 8.2 for
details of the options relating to this feature.
sorry no do not have the digiplan manual , thanks will check the motor
regards
Dave
regards
Dave
There are also a couple of fuses & LED's on the card that the CD20 drives plug in to.
If it is CD20 then the manuals are here:
viewtopic.php?f=15&t=561&hilit=parker
I was qouting from a Parker Digiplan HFC DC servo drive manual, so it's probably duff info
