When I run Techsoft Ver 2 the drawing size does not match the Versa Laser (VL 200 in this case bed size), it is only 297 x 297 when i go into the following.......
SETUP > DRAWING > LAYOUT > Match to current printer (Which your laser should be set as your default printer)
With the Laser powered up and connected to the PC with a USB cable. From the PC select START > PRINTERS AND FAXES. Find the VL200 driver and delete it. Then ADD A PRINTER, go into the Add Printer Wizard.
Select Local Printer
Select printer port ---- VERSA-1 (USB Port to VERSA)
Manufacturer ---- Universal Laser Systems
Printer ---- VL200
Printer ---- VL200
