VR Milling v5.33 released 22nd April 2010
Check here to download the latest version of all software:
Changes since v5.31:
v5.32 - Updated Vrmilling.exe and Denvrxm.ocx to not crash when the users appdata\denford folder is empty
v5.32 - Added menu Setup > Debug Machine I/O - only works on Nextmove ST green or orange display LEDs
v5.32 - Updates for CE machines - new firmware 5411, MintControls5624.ocx and new EasyUpgrader to support it. BigMint.mnt is the new single .mnt file
v5.32 - added an error for estop checking - if say, estop relay contacts have failed then contact denford
v5.32 - nb, newest version of milserver5500.exe also needs VirtualController.dll to be in the same directory for it to self-register
v5.32 - updated scanning to support new controller (56xx)
v5.32 - updated alloffsets.MOF and added MILL_Default.MOF and ROUTER_Default.MOF
v5.32 - Updated machine select screen and added a tutorial on selecting and configuring the correct machine
v5.32 - added ExplodeSplines in ImportWizLayers to fix curves from Solidworks DXF files coming in clunky
v5.32 - added Warn on play checkbox to the setup > execute mode menu for warning when pressing play on the real machine
v5.32 - change vertical router esb55 mint to fix issue of guard open message appearing at power on (even though door is closed)
v5.33 - altered router 2600.dll to move aluminium table to correct position.
v5.33 - added M01 button to allow optional stop M01 to pause the program
v5.33 - altered scanning wizard to not try and show both original and editable models at the same time
v5.33 - updates to easyscan tutorial - it's also changed from a .chm file to .pdf
v5.33 - updates to easyscan wizard to check number of scanned points - also allows user to save a raw point file (.asc) format before trying to create STL
nb, MeshLab is open source software which is able to load the raw point files (.asc) created by the scan wizard.
v5.33 - changed the way G83 works - it's now like it should be as shown in our help and in Fanuc books - made a document called G83-Peck-Drilling.docx
v5.33 - first 64-bit USB drivers added to install CD
