How to change the Top Card on the NextMove controller.
The top card on all the controllers supplied from Smartstep, Denstep to NextMove can all be replaced in the same way.
Wether upgrading to a newer top card or fitting a service replacement the principle is the same.
Attached is a PDF booklet that tells you how to do this.
The PDF should be printed back to back then folded in half then stapled.
Nextmove top card replacement.pdf
(519.49 KiB) Downloaded 1697 times
