Reset password in VR Milling v5 and VR Milling v2
Post by Denford Admin » Wed 13 Jan , 2010 10:34 am
If the setup password has been changed and now forgotten, you can reset it back to the default (denny) here:
VR Milling v2:
To reset the setup parameters, you need to find windmill.ini normally in C:\Program Files\Denford\VRMilling.
Close VRMilling first
Open the ini file with Notepad or any text editor. About 30 lines down will be an entry like this:
Access=E6JA-UT98-12BV-YDP
Just delete this whole line, save and close the file, and the password will be reset next time you run VRMilling
VR Milling v5:
To reset the setup parameters, you need to find windmill.ini normally in C:\Documents and Settings\USERNAME\Application Data\Denford\
