LaserCAM and QuickCAM 2D v1.10 released 2nd Nov 2009
Changes:
QuickCAM only:
// 1.10 - Fixed a problem where the billet is less than 10mm you get a Z outside billet warning when checking output
// 1.10 - improved circle and arc output
// 1.10 - Fixes to make auto-sending CNC output to VRMilling 2 or 5 more reliable
// 1.10 - Improved output of all CNC paths to favour CW direction (when sort paths is ticked)
// 1.10 - Added profile direction arrows to CNC output simulation wizard- clicking on the profiles will change the toolpath direction
Both QuickCAM and LaserCAM
// 1.10 - Fixed the drag and drop routine to import things like dxf and eps better when dropping files on
// 1.10 - Gerber reader changes to read multiple commands on each line (denoted by * in the .gbx file)
// 1.10 - Added image mirror into image adjust screen
// 1.10 - minor changes to contour bitmap - its much better with shapes like lettering
As usual - check here for the latest version:
