RS232 Machine Link Cable 9 - 25Way BI01812GG
Post by Steve » Thu 17 Sep , 2009 11:11 am
The External Machine link Cable part number is BI01812GG
This cable was manufactured by Lindy and is black in colour.
The cable was used on all machines (other than the MicroMill and MicroTurn supplied in the USA)
The Internal serial cable used in conjunction with this cable was BI01812A
Pin outs of the Machine Link Cable...
9 Pin Female (computer end) 25 Pin Male (Machine)
9 Pin 25 Pin
2 --------------RED----------------------2
3 -------------WHITE---------------------- 3
8 --------------BLUE---------------------- 4
7 --------------BLACK--------------------- 5
5 -------------YELLOW-------------------- 7
(1, 4 & 6 linked in 9 Way) (6, 8 & 20 linked in 25 Way)
Re: RS232 Machine Link Cable 9 - 25Way BI01812GG
Post by Steve » Thu 17 Sep , 2009 13:43 pm
PDF Cable Drawing
BI01812GG.pdf
(17.34 KiB) Downloaded 3679 times
762x51
Hardware/Software: MicroTurn
MicroMill 2000
VR Software
Post by 762x51 » Fri 26 Oct , 2012 17:56 pm
Steve wrote:The External Machine link Cable part number is BI01812GG
<SNIP>
Would you please post a drawing of the cable used in the USA and also one of the BI01812A cable?
Thanks,
Orin
"It is well that war is so terrible -- lest we should grow too fond of it." Gen. R.E. Lee CSA
Post by Steve » Mon 29 Oct , 2012 14:44 pm
The attached post shows the internal cables.
I believe you have a US MicroMill and a Microturn so the internal cable you have fitted will be: BI01812B
The external cable is a BI01812N This is a standard Null modem cable.
viewtopic.php?f=36&t=2384&p=8630&hilit=BI01812A#p8630
The attached link shows the connections required if you connect a cable directly to the Baldor control card to the PC:
viewtopic.php?t=231
You can buy a cable in the USA from Newark
PRO SIGNAL - PSG90340 - LEAD, MODEM, 9WAY-25WAY D SOCKETS
Newark Part Number: 43T6042 Manufacturer Part No: PSG90340
https://www.newark.com/pro-signal/psg903 ... dp/43T6042
See attached drawing of cable (this would allow connection of 25 way to 9 way or 25 way to 25 Way)
NULL MODEM.pdf
(831.24 KiB) Downloaded 1750 times
762x51
MicroMill 2000
VR Software
Post by 762x51 » Wed 31 Oct , 2012 2:31 am
viewtopic.php?t=231
SUCCESS.. :mrgreen:
Thanks Steve,
I made a direct PC to Baldor Control cable and it works great!! Thanks for your help.
Orin
