Versa Laser will not run on a replacement PC
If your Versa Laser has been running OK and then you try it with a differnt PC, the axes may home and jog about OK bur when you come to start cutting the Versa Laser just does nothing
This is a probably a restricted user problem.
You have to give FULL CONTROL permission to the following folders:
\Program Files\ULS
\Program Files\ULSdb
\Documents and Settings\All Users\Application Data\ULSVL
The last folder is a hidden folder, so the administrator must turn on
"Show Hidden Files and Folders" setting in the Windows Explorer, View
menu, Folder Options, Advanced Settings dialog box.
