TP 128 Toolpost height adjustment procedure
Customer writes
"What is the procedure for adjusting the tool height on a TP 128 Toolpost ?"
1. Turn power on to machine and connect software
2. Slacken both locking nuts on grub screws (See picture below)
3. Slacken one grub screw and check if the tool point is going in the correct direction. I.e. is it aligning with the centre line of the chuck / billet ?
4. If the tool point is going in the wrong direction, screw the grun screw in WHILST INITIATING AN AUTOMATIC TOOL CHANGE VIA THE SOFTWARE. Repeat this procedure until the tool point is aligned with the centre line of the chuck / billet ?
5. Screw in the other grub screw until it comes in contact with the rachet tab (See picture below)
6. Retighten both locking nuts on the grub screws.
If toolpost hangs up the software after performing a tool change, check out this link below. It may just be admin rights on the computer
viewtopic.php?t=1990&highlight=toolpost
TP128 Tool Post 1.jpg (100.36 KiB) Viewed 12567 times
TP128 Tool Post 2.jpg (78.72 KiB) Viewed 12568 times
Re: Turret
bradders wrote:1. Turn power on to machine and connect software
Bradders
Is it possible to get the dimensions of the auto tool turret? Do you have complete pictures available ?
Thanks,
Iron-Man
Re: TP 128 Toolpost height adjustment procedure
We have the drawings but they are commercially confidental.
bradders wrote:We have the drawings but they are commercially confidental.
Dear Denford Admin
I do not want detailed drawings. Can you just tell me the dimensions of the rectangular box? and the distance from the bottom to the center of the tool turret shaft in the picture in the above post.
Thanks,
Iron-Man
Dear Denford Admin
Just so everyone else knows I didn't ignore you, I answered here:
viewtopic.php?f=42&t=3214
