Viceroy 280 VS Lathe Manual
Viceroy 280 VS Lathe.pdf
(861.25 KiB) Downloaded 5089 times
Re: Viceroy 280 VS Lathe Manual
Dear bradders,
I have a Viceroy 280vs lathe at my place of work.
I have downloaded the Lathe Manual OK. Many thanks for making it available.
Is there any chance of the electrical circuit diagram being available anywhere ?
Yours,
Andrew
Which 280VS model do you have - manual variable speed (with handwheel mounted on front of stand) or electric (joystick on control box mounted above headstock)?
I have the electrical schematic for the latter - will post a scan or give you the number for Admin to find - may be a couple of days though.
Denfords don't have the circuit board data as they were outsourced - but I have a self-drawn schematic for the later speed readout board if needed.
Many thanks for manual, it was most helpful
Andy B wrote:Which 280VS model do you have - manual variable speed (with handwheel mounted on front of stand) or electric (joystick on control box mounted above headstock)?
I have the latter. Any chance of a copy of the schematic?
Many thanks, Mark.
