Compact 1000 not connecting
All info relating to the Denford Compact 1000 and Compact 1000 Pro small routing machines
boots
Post by boots » Tue 21 Apr , 2009 21:40 pm
Compact 1000
VR Milling v5.26
The machine has been working fine until today.
Tried to connect to the machine and the error message "Must Use A Set xxxlink Function" pops up.
There is a "-" in the orange LED Status Display.
Any ideas on what to try?
Post by Martin » Tue 21 Apr , 2009 22:27 pm
boots
Post by boots » Wed 22 Apr , 2009 19:26 pm
This unfortunately did not help. We are still getting the same error and we tried re-installing the drivers, restarted and checked the cables etc. We are also getting the error E06D7363 after we start VR Milling and try to connect to machine.
Post by bradders » Thu 23 Apr , 2009 9:17 am
Boots,
If it is a USB connection try a cable directly from the PC to the Baldor control board. It could be that the USB bulkhead fitting is faulty. Just to be 100% sure you could try a different USB cable as well :lol:
Post by Denford Admin » Thu 23 Apr , 2009 9:24 am
It'll be worth installing Mint Workbench off the VRMilling CD - See if that can find the machine.
Another thing to try is this:
viewtopic.php?t=2061
boots
Post by boots » Fri 24 Apr , 2009 17:13 pm
Thanks. It took several driver re-installs but we got it working
