DOS Fanucsmd (v2.77) connection problem to MicroMill
Posted: Mon 09 Feb , 2009 14:52 pm
We are currently trying to set up two older 98' laptops to work with some Micromill CNC's. The desktop PC's that were working very nicely with these two mills, were sent to the recyclers last summer. So I am not able to access those PC's for comparisom. We are using the DOS Fanuc Milling CNC programming (v2.77). The laptop serial port is set to COM1. I have the Fanucmd.go file setup as follows.
IBM.RS2 2
$3F8 4 COM1
$3F8 4 MACHINE
QDENFORD.KYB 1
18.2 0
VGA.CRT 0
FANUCSMD.APP
When I run the Fanucsmd.exe program it acts like it wants to connect to the CNC Mill. But, it hangs at "Initialising MINT3.28.". From reading the forum pages I have come to believe that this is a common error. The only difference between the setups from last school year,
is the laptop's instead of the 10 year old desktop's.
Thank You for taking the time to read this post. If you could provide any help it would be greatly appreciated.
IBM.RS2 2
$3F8 4 COM1
$3F8 4 MACHINE
QDENFORD.KYB 1
18.2 0
VGA.CRT 0
FANUCSMD.APP
