WHY IS IT NEEDED AND WILL THE MACHINE FUNCTION WITHOUT IT?
WHERE CAN I GET A REPLACEMENT AS MINE HAS LEEKED?
My 2 cents worth!!
All the CNC machines I have owned/own that have a battery on a board it is usually needed to hold the NC Parameters on the machine, the Denford machines I have owned/own do have EPROMs with the Denford software on and aren`t affected whether the battery is there or not as the information is "burnt" onto the EPROMs.
However, the machines NC Parameters are usually able to be changed (All mine are!!) and if the battery is removed the Parameters are lost!!
I recently installed 128K of memory on one of my Denford Lathes and I had to save all the machine Parameters out as the battery had to be disconnected to install the new memory and the Parameters re-loaded again.
So, it is possible the battery is there for a good reason!!
Just my 2 cents worth!!
Rob
Rob
The MAJORITY of firmware versions used by Denford on the Eurostep board makes no use of the battery and it can safely be removed.
The ones to watch are a few versions of Triac / Novamills with ATC. I think some of these machines that ran v2 VRMilling may save the current ATC position in NVRAM on the card, so no battery would make the ATC forget where the carousel is when powered down.
