How do I conect to an Easturn 3 with PNC3 control ?
This is the only drawing we have for a IBM to PNC3 control cable
See this thread for Easiturn manual
viewtopic.php?t=1682&highlight=pnc3
IBM-PNC3 cable.pdf
(19.38 KiB) Downloaded 947 times
On mine, it had a din socket on the back, but the wiring did not match any of the diagrams I'd seen. Inside the case there are three wires connecting to the socket. Black, Red and Blue. Black was the ground, Red and Blue the Tx & Rx (may be the other way round).
I just soldered them on to a D9 connector and put that on the back instead - now any old serial lead will work.
If I remember, I'll give you the colour to D9 connections
Si
