Triac Central lube pump
Here is the datasheet for the Triac central lube system pump. The are variations but if the same make then they follow similar lines.
21383_B_LUB_TM1_DS.zip
(96.45 KiB) Downloaded 1452 times
Early Denford metric manual Mill
Retrofitted Triac
Easiturn-3
