Light Machines - Post Processor
Anything to do with configuring CAM systems and Post Processors to run on different CNC machines
Benny
Post by Benny » Tue 20 May , 2008 18:50 pm
I need help in getting a post file that will run on our Light Machines educational mill.
the Larken Camtool post does not work...although the G-code looks vary similar...the light machines will not read how the tooling information is written.
I have attached a sample engraving file of a snowflake from the Light Machines Mill software. Perhaps that can help you figure out a post file for the Light Machines mill.
thanks, -OV-
flake2006fix.zip
(5.07 KiB) Downloaded 1011 times
Post by Denford Admin » Wed 21 May , 2008 10:44 am
Can you try this file out on the proLight please ?
It should be nearer to what you need...
proLight.zip
(2.87 KiB) Downloaded 1085 times
