Scoring onto card
Len Charnock
Scoring onto card
Post by Len Charnock » Mon 19 May , 2008 12:46 pm
I am having problems trying to score a line onto 1mm card. I create blue lines but, even at "paper" setting with the vector marking turned to minimum, the laser still cuts through the card. Is there any way I can reduce the power further? Can the matrials database be edited to give me a suitable setting for this?
(If I use black lines, the correct amount of scoring is achieved, unfortunately, it takes too long on vertical lines as the machine is rastering horizontally).
Post by Steve » Mon 19 May , 2008 14:23 pm
Len,
What version of driver do you have?
Is the machine a VLS?
What is the laser power?
If you do not have the latest driver and you have a VLS download this file:
http://www.denfordata.com/downloads/uls2008_2.19.34.zip
The material library has lots of corrections in this new version :D
Len Charnock
Post by Len Charnock » Wed 21 May , 2008 13:25 pm
VLS 40w machine using latest software (2.19.34) downloaded and installed this week.
Post by Martin » Wed 21 May , 2008 15:21 pm
Have you tried to re print the design. The settings for each printed object are set when it is printed.
