TDS/25/B/D Linishing machines,wiring diagram required
I am after a wiring diagram for one of your linishing machines. The Model is TDS/25/B/D. Serial No BD26100A. Voltage 415. .75HP. Date Oct 1990.
You could try this:
SK618 TDS 25 3ph Wiring Diagram or
A3-800006 - TDS25 with remote control 3 ph.
And whilst having a look through the SK numbers, if you come across SK831 and SK839 (both for Senior Millers) I'd like a copy.
Andy,
Can you check that the A3-800006 is the correct No, i cannot see any A3-8 in the drawing registry
SK618 and SK618A.pdf
(864 KiB) Downloaded 1237 times
SK831 and SK839.pdf
(71.52 KiB) Downloaded 2205 times
Re: TDS/25/B/D Linishing machines,wiring diagram required
Can anyone tell me the length!/circumference of the 150mm wide linishing belt on a Viceroy TDS 25 machine?
JPopowski
