Customer writes in----- I used a computer cord to try and power up the spindle on our demo router and it did not come on.  I tried it with the router turned on and turned off, it made no difference.  Do I need to have it attached to a computer, with the VRmill running, in order to directly power the spindle?  I toggled the switch on the spindle on and off numerous times with no results.  Any suggestions?
    				    			With the black machine cable that came with the Microrouter Compact  (i.e. similar to a computer cord) plugged into a wall outlet and the Porter Cable spindle motor cord plugged into this black machine cable (i.e. computer cord), the motor should run using the On/Off switch located on the side of the spindle motor.  If not, then the motor brushes are worn out or the On/Off switch is defective.
You may also want to try knocking our or blowing out with compressed air, any balsa dust from the top of the motor.
If still not working after trying above suggestions, you may have a faulty motor.
