From the VR CNC milling materials library, I can see that for steel a feed rate of 75 mm/min and a spindle speed of 2500 rpm is recommemned, but I was wondering about milling stainless steel. Would these setting differ much?
I am also considering milling Lead. I understand this tends to clog the flutes of conventional cutters.
Any suggestions on speeds, feeds or tooling for these jobs?
I'm using a VMC1300 Pro. The stainless steel is just 1mm thick Sheet, the Lead is a solid block.
thanks
With the Stainless I would just take shallower cuts and use the same feeds and speeds.
What you may want to do is program a faster feed and speed then use the feed and speed override knobs until you get the best cut then record the values.
Lead could be more of a problem as it tends not to chip.
If you ever try to drill with a hand drill the tool tends to grab and can hurt your wrist.
Hopefully someone else has some evperience of this but i could see it stalling the spindle if you take too big a cut.
