Fixed row count must be less than row count
I have a problem while using Denford Virtual Reality.
When storing the points for the robot (currently working on Robot room 1) If I try to edit the memory in the Robot1 Panel I suddenly get an error:
____________________________________________
| Denford Virtual Linker
|___________________________________________|
After this happens all my previously stored points are deleted and even if I try to store more points they keep getting deleted...
Any Ideas?
Thankyou!
Were you trying to delete some entries in the robot moves table at the time?
The message indicates that the grid on the screen that displays the robot co-ordinates has been reduced below it's a preset minimum (not sure what this minimum is but it will be a fixed value in the VR Robot source code).
Or let me know more about what you were doing when the problem happened.
:shock:
I was progamming a point sequence for the robot.
Every now and then would save the memory to a file (in case what keeps happening happened again :? )
Then I tried to see the memory grid thing (Edit I think it is) and instead of showing me the memory, it gave me the error. Then It shows a completely empty memory in that list thing...
Once the error has been shown, no matter what I do, I always get the error when I try to go into the Edit dialogue and can never actually see the list of points, I mean, I can see it, but it's been emptied!
I seem to remember updating the code a while back to help fix sequence table entries going missing - as I remember it was problems with NT (which you'd also get in XP) over windows 95/98
Have you got the latest version ? (see: https://www.denford.co.uk/technical-support.asp)
Mr Magoo, Martin, Steve
