Yeah, work great, got one of each, but....
don't expect much from the controller - the technology is 20 years old (maybe more) If you get these machines they are well built but expect to refit the control system with something like Mach3.
Unless yuou find a fanuc controlled triac, they're not too bad but limited on the size of the program you can load - with mach3 the only size limit is the size of your hard drive
Orac's program size is even smaller at around 500 lines (if I remember right) assuming you can get the computer to talk to the machine;)
www.la-coterie.com
